1 - 3 of 3 Posts
I need help :confused:
When I turn my bars hard right, in the garage to maneuver for example: My throttle is locked.  I can not turn it.  Hard left no problem...
I played with the adjustment under the bar with no luck.  Is there an adjustment at the other end of the cable?  Also I have replaced the tie-wraps with chrome clamps, the outside cable housing is not tight at all...
This was happening to me too. I found that the throttle cable was being pulled tight accross the bar riser, causing the cable to get pniched inside. I called the dealer and they asked me to bring it over ASAP so they could look at it and fix it.
For now I tie wraped the cables together and that seems to have fixed it temporarily, but I think the cable will need to be re-routed.
Lygriek,
aka: Michael
1 - 3 of 3 Posts
