OK, I ordered Kury ISO grips and want to install grip warmers before I install the grips.
I have searched high and far on this site for a recent step-by-step to see if these are easy, fairly easy, or nigh impossible to install on the 109.
Up to now, I have deduced that there are end weights in the bars that need to be drilled out...what does that entail? Do I have to take the bars off the bike (thereby having to remove everything to get them off) of is it possible to work on them while still attached?
Anybody able to list the steps they had to take and if they have pics, that would be great also?
Also, did you run all the wiring inside the bar and then drill a hole in the center and run the wiring down the front to get power or what? I am trying to scope this before I set sail and make a mess of things.
