1 - 10 of 10 Posts
I thought I saw a thread on this but it may have been within another thread. I seemed to notice it bouncing around some but don't really ride too much at night. I washed the bike today and noticed the whole headlight assy cowl and all move up and down quite a bit. I am at work and no service manual with me but it seems to be rubber mounted and most times they use a shouldered spacer so it can only go so tight with the bolt and the rubber gromets are supposed to do the rest. Has anybody remedied the bouncing headlight? thanks.
No this movement is more like 12mm (0.5") or so when you put your hand under it and lift it up and down. looks like the bike has one of those headlight modulators on it when on a bumpy road. some others have reported it but if it is bolted down like I think it is with a spacer and bolt through a grommet it probably means the spacer is a tad long and needs to be ground down or the rubber grommet is not thick enough to take up the slack.
Since it looks like it's built in design :D I may see if I can put a small piece of sponge rubber silicone in the small gap between the chrome cover the turn sigs bolt to and the bottom of the headlight. It would still be rubber mounted but should stop some of the bounce. thanks all.
I noticed mine moving, especially after I put on the Suzuki sport windshield. I put a concave washer on each side to put a little more tension on the cowl. No movement now.
I was startin' tuh think I was the only one with this headlight wobble issue . I took it off a few times for wire access and such couldn't see anything missing or wrong in there , it all lined up nice and still wobbled up and down so bad people were flashin' high beams at me. When I have my windshield on there I jam it under the headlight cowl with some tension on it so the wobble goes away on trips at least .I'll have to try the concave washer trick.
Dave
1 - 10 of 10 Posts
