100+ hp and 90+ on torque. How that for a nebulous answer.Jonce said:What's your guess? Mine is 122 rwhp and 103 ft lbs trq. Just a guess, haven't had a chance to ride one yet. I have another 4 weeks before I can buy one![]()
HalHalGreenlee said:Just remember that whatever results that Lamont gets today apply to his bike only, on that particular dyno at the atmospheric conditions present when they do the dyno.
So don't get too bummed out either way if your numbers are different than his.
I got to tell you the bike feels faster than the numbers are showing but did you look at how fast that torque comes up!traysvega said:Wow ,more than enough at the rear wheel....For me,,,for now..Thanks Lamonster......
I currently own a V-Rod. Typical rear-wheel power for a stock bike is 112hp / 76ftlbs. Typical mods would be: Replace the OE air filter with a K&N, new exhaust, and a fuel manager. With a slip-on exahust system, owners are generally seeing another 2-3 hp and 1-2 ftlbs. With full exhaust, around 117-118 hp and 79-80 ftlbs. Other than these mods, there isnt a whole lot you can do to modify the engine unless you are considering serious, expensive mods. ie...Big-bore, turbo, nitrous.ditch said:Just curious if anyone know the hard facts about HP on the v-rod. A guy who ones one said it has 111 but when I rode it, my 109 had alot more than that. Did they pump up their HP numbers too? He also said it did the 1/4 in 11.2 Is that possible with a stock bike?
The bike was getting warm and I didn't have the back strapped down as tight as I would have liked.J R said:I think maybe the guy might be a little mislead.The bike from Suzuki is mesured in crankshaft h.p. with God knows what correction factor. I dont think Lamonsters 109 is off by 27 h.p.Actually his chart is really about right on with comparing other bikes Dyno rear wheel h.p with factory rated H.P . Everybike and different dyno,s and different times of the year and weather and rear tires used e.c.t affect dyno readings.Look at the two graphs above and the difference in #1 run and number 2 run. Im guessing the bike started to get warm ????
Yes I know they are just tools, but I just wanted to pass it on.J R said:I think maybe the guy might be a little mislead.The bike from Suzuki is mesured in crankshaft h.p. with God knows what correction factor. I dont think Lamonsters 109 is off by 27 h.p.ÂActually his chart is really about right on with comparing other bikes Dyno rear wheel h.p with factory rated H.P . Everybike and different dyno,s and different times of the year and weather and rear tires used e.c.t affect dyno readings.Look at the two graphs above and the difference in #1 run and number 2 run. Im guessing the bike started to get warm ???? Honestly I wouldnt get to caught up in dyno wars.Its all in the rider and power to weight ratio.Dyno,s are great tools but thats it just a tool.
That sounds about right for top speed. I was doing around 125 and close to 5000 rpms in 5th and had plenty of pull just not enough safe distance.Lamonster said:Well it's not what I had hoped for but it's close to what I thought it would be. This was done on a Dynojet 250. We didn't do fuel air and we only did a 4 gear roll on. Ken thought we could get some better numbers in 5th but I had already pulled the bike off and now I have a baseline to work with. One thing that I thought was pretty cool was the bike topped out at 127 mph in 4th.. ;D
Here's the chart.
http://image2.frappr.com/pix2/i/20060413/4/5/b/45b277d3c19ded1038e153d6c2e3c7600
You must be a Harley rider or maybe a Warrior. In the real world, a graph would show the M109R kicking @ss.Fritz said:Â Sorry thar Bubs,but you don't know what yer talkin about.!!!!!!!!!!!
 A dyno gives the conditions AS ARE.
 Are you dumb,er what.
 A Dyno is like a drag strip.On damp days,where Barometric pressure is way off
 and the humidity is High,ya get bad runs.Why would a Dyno compensate for a
 given. A dyno is as close to a genuine reflefction of the Engines performance.
 That is why they differ some.If an engine is overheated and it's raining outside,
 then the dyno in the Back room will still reflect poorly.
 BTW,This Lamonster dude,never gave us his official Dyno results.
 He just kinda winged a guess.
Not very accurate,for someone interested in Performance.
