1 - 12 of 12 Posts
Was wondering if anyone else is fighting to find neutral and is this a sign my clutch nut is acting up? I have an 07 with 17,500 miles on it and I've been noticing in the past week or so I have a terrible time shifting into neutral from first or 2nd gear. Thanks
Too much clutch freeplay? Maybe your cable has stretched a bit, and with too much freeplay mine is hard to get into neutral.
I have had the factory pro shift kit in since day one and it is always very hard to find netural for mine it takes a very light touch.
Easier than...
Finding N is much easier on the M109 than on a Cavalcade. I have no problem whatsoever.
:agree: check clutch free play at the lever. When my nut came loose I got stuck in gear and it would stall when I was able to shift from N to 1st. Ended up getting stuck in 2nd and driving home. LOTS O FUN!!!
Check your cable adjustment, I'd say it's not releasing enough and keeping pressure on the plates. Mine works better if I kind of feather the clutch a little while clicking it into neutral too. The cable adjustment makes the most difference though.
I have had problems finding N for awhile and then my cable snapped. It would jump over N. Not sure if it was related but as soon as I get my Barnett I will find out
No issue with mine. But after installing the evo star kit you just barley need to touch it and it goes into neutral.
I would think it`s your clutch plates need replacing!! As my buddy's did the same thing! ( very hard to find neutral) I ordered & replaced them and now it is like it should! be from new, :bigthumbsup:
Thanks to all I will check my cable adjustment. I've been running the Barnett 2nd generation cable and star shift kit for awhile now.
Let the clutch lever half way out and it will shift right into nuetral
1 - 12 of 12 Posts
