around 0.4 inch wide, but you can go wider.that works :bigthumbsup: think I will try it what size led stripe did you use I installed a bunch of leds over the winter and never even thought about that area
thanks will try using spacers thinking of having a ring made at work with two or three tabs where the screws go on the derby cover to hold it in place will let you know how it comes out.around 0.4 inch wide, but you can go wider.
I tried spacers between engine and derby and that gap did the trick, now one can see the halo light much better
You can't see them were i routed them now, along the footrest bracketLooks good, but I would hate the wire thats exposed at the bottom. Not worth it to me!
Exactly :bigthumbsup:I would have the wire come out more in the front of derby cover where the bracket for the pegs can hide it better
