1 - 16 of 16 Posts
Can any tell will i loose any handling or power going to a 280 tire?
As far as power, nothing that you will be able to tell out on the street...guaranteed. I have raced 280 tire bikes with my 250 tire, similar mods, and the race is so close that it isn't worth even having the debate. :bigthumbsup: I personally cannot comment on handling, but from what i have been told from the 280/160 combo people...it is awesome.
there is some handling loss from stock to 280... ya gotta lean into it harder and it tries to stand up on ya...
Can any one tell me will i loose any handling or power going to a 280 tire?
I have not noticed a difference in the power, probably not noticeable like Big Papa said. The only difference in handling is that you lose some ground clearance, but I also lowered mine 2". All in all I have no regrets, and looks GREAT:bigthumbsup::drool:
I had a 280 on a stock rim and the handling was crap scraping every time you went around tight corners i changed to a 250 and it was a big inprovment .
also the 280 is made for a wider rim and they wear bad on the sides on a stock rim as they are not stretched enough .
this 280 was installed on factory rim on mar 2009 and made around 15000 km , still in good condition, no ubnormal wear issues :dontknow:
I have a 280 on a 10" wheel and it handles fine but a huge difference from the stock set-up. You have to push the bike harder in turns and it will try to stand you up. Regardless, I wouldn't have it any other way... except a 300 maybe :D
280 with oem wheel or 10" wheel what u doing!
makes a difference!anyways i run a 250 with oem for winter& 280 10"wheel most of the year what handles better! the 250 what looks better the 280
280 with 10" wins !
drive safe!
thanks
thanks for getting back to me everyone after reading what everyone had to say just order my new ravens! Now what rubber should i put on my new rims? Not use to the width so dont know.:dontknow:
Any new size tire has a learning curve to it. Get what makes you happy, the one that you like the looks of the most.
1 - 16 of 16 Posts
