Premium only - I haven't found 91 octane midrange.Do you put in Midrange or Premium on your 9? Pro's - Con's.
The octane ratings are calculated differently overseas. It's not actually that much higher.Wow, our premium goes to 98 here in Australia.
2007 Black M109R
funny Zuk recommends 90 or above on the nine but in the owners manual of my busa, it recommends at least 87. i just use whatever book recommendsI had to run 87 on a fill-up because the station didn't have any 91. Bike runs great so why buy the expensive stuff? :dontknow:
you may want to do alittle research. Higher octane doesnt burn any cleaner then lower TBH, the only thing an Octane # is telling you is its resistance to knocking, or detonation is better. The lower rated fuel you can run the more Hp you will make. Now alot of the Oil companies actually add more detergent, to their higher octanes also. They may help clean the inside of your intakes, and valves etc of deposits, but you will make less power on them. Here's a link with some more info on the subject.I always run the highest octane at the pump, which is typically 94.
I find the higher octane will give me better gas mileage. But more than that, if you're really paying attention, the engine runs better and is more responsive as the higher octane fuels burn cleaner.
My comment is based on my own experience, over the life of all of my vehicles for the past 10 years, comparing different octane fuels to the resulting performance and mileage. Was this on a closed course with controlled conditions or on a dyno? Of course not. But I'd rather take my own results over someone else's, as mine are specific to my driving styles, air temp, and environment. Thanks for the link though.you may want to do alittle research
Agree. There is no reason to run a fuel of higher octane needed than to prevent knocking. Lower octane fuel burns faster than higher. I get good mileage (mid thirties or better) and have never had one ping even on really hot days. Mine made really good HP/TQ on the dyno running 87 octane as well.I had to run 87 on a fill-up because the station didn't have any 91. Bike runs great so why buy the expensive stuff? :dontknow:
The issue i had with your comment was about burning cleaner. Unless your driving around with a 4 gas analyser, and comparing each tank just wanted people to realize thats not a true statment higher octane, doesnt mean cleaner emmisions.. Since part of my Job deals with air monitoring at work, I here all sorts of misconceptions. About ride quality to each his own. I ran everything from leaded fuels to Av fuels to 118 race fuels in my different vehicles some combos run better with others.My comment is based on my own experience, over the life of all of my vehicles for the past 10 years, comparing different octane fuels to the resulting performance and mileage. Was this on a closed course with controlled conditions or on a dyno? Of course not. But I'd rather take my own results over someone else's, as mine are specific to my driving styles, air temp, and environment. Thanks for the link though.
Here you go this is how the get the numberThe octane ratings are calculated differently overseas. It's not actually that much higher.
:agree: Nothing but the best!!Nothing but the best for the nine.
