The bike was running fine. I had it on a lift when I started it up. When switched tanks it stopped priming. The relay is not clicking on the bike, but when I tested the relay off the bike I heard it click. It is reading the right ohms. The bike is not getting fuel but it turns over like it wants to start. I don't have the Fi light on, speedo works, all lights work, and all spark plugs are brand new. It seems like the red kill switch on the handlebars isn't working? I'm finding it very hard to believe that it is the fuel pump because I can't even get a clicking sound. It is not the kickstand switch. I didn't even ride the bike, but just had it running on the lift. Like I said when switched tanks it wouldn't start. Everything is plugged in. I do have the "CHEC" on the speedo. I checked every fuse and they are good. The battery is reading 11.74. How do you check the red killswitch to make sure it is sending power to the relay?
