1 - 20 of 27 Posts
Which size of fornt tire should I get for rear 260 metzeler?
(!!STOCK RIMS!!). And also... should I get reinforced version or regular one? I am thinking about this :
ME 880 Marathon 140/70 - 18 73H reinf TL
but I am not sure about it... should I get wider (160? or..?) and with or without reinforcement?
Thanx fellas
Discussion Starter · #5 · (Edited)
But Metzeler´s website says, that 160 is for the rear wheel... is it gonna make some troubles while turning or not? There is 140 Metzeler and they says that it is for front... so help help meeee (I am not from USA, so I have to curve oftenly...I would prefer cruising on the straight roads, but... Europe is diferent in this way :-\)...
http://www.metzelermoto.com/web/cat...eType=MOTO&menu_item=/products/catalog/custom
The 160 is a rear tire. If you get this, all you have to do is mount in the opposite direction of the directional arrow on the tire. You have to mount it backwards. No other mods necessary. You will be fine going with the 160.
140 is the largest front tire Metz makes. Either tire you will be fine with.
I currently have a metz 280 rear and metz 140 front. When my front wears out, I'm thinking about going to the 160.
So go with whatever size you feel the best with. Both will do well in the twisties in Europe!
Discussion Starter · #9 · (Edited)
the 160 fits fine on the stock rim??? does it affect handiling???
I run a 160/60 metz I run it in reverse the only difference I found that the bike is slower in response in turns Meaning the it doesn't lean over as quick as it did when I had the 130 keep that in mind when making your turns this is just one man's opinion and every one's riding style is different!!
I run a 160/60 metz I run it i reverse the only difference I found that the bike is slower in response in turns Meaning the it doesn't lean over as quick as it did when I had the 130 keep that in mind when making your turns this is just one man's opinion and every one's riding style is different!!
Thats b/c you have 30mm more to lean over, thats equilvlant to 2 more inches you have to move. 2" may not be a lot, but it is when we are talking rubber. If you want a more responsive tire, you need to go slimmer. Think about it, how many race track bikes ( not drag bikes ) have big tires? The answer is and will always be, NONE.
1 - 20 of 27 Posts
