1 - 4 of 4 Posts
Im going to have to remove the brakes lines to re route them. Do i have bleed them when i reconnect them. If i do what do i need to do?
Yes anytime you break the connections, you need to bleed them. This is what I use to bleed mine. If you don't know what your doing, get someone that does. You want to make sure that the brakes are done perfectly. Your life and someone elses may depend on it.
You do not necessarily NEED to remove the brake lines.
For some rerouting goals, you can unbolt the calipers and work with them still on the ends of the lines.
I am not saying that will work for your goal, but do consider it.
1 - 4 of 4 Posts
