1 - 1 of 1 Posts
So I had my inner rotors powder coated OK so I had someone put everything back together and they also filed the inner part to set the rotor in properly, now I'm hearing a brake sensor noise coming from the front brakes so I removed all 4 pads and sanded them along with sanding the rotors so I finish up and take it for a ride well the noise went away until I hit the highway and it came back now should I get new pads or something else,it seems like as soon as the rotor gets hot the noise comes back and stays until I sand the pads again and then its good until I get the speed up again. Should I change the pads? ?? Thank you
1 - 1 of 1 Posts
