1 - 16 of 16 Posts
I Decided to Change up the front blinkers a bit...I made them closer to the forks.I did'nt like the way they stuck out. it was a little mission but with the right tools your good...let me know what u guys think??:bigthumbsup:
Very Nice man. You should post for anyone else who wants to do that. I know I'd be interested.:bigthumbsup:
yea post a how to please
Good job, they look a lot neater. I think they would look even better if you put some clear lenses on them. :bigthumbsup::bigthumbsup:
Yeah post how you did the mod? And I agree with Zoom Clear Lenses.
Thanks everyone for the good remarks....yeah i know about the lenses, ima smoke them out same with the tail light.8)
Discussion Starter · #8 · (Edited)
ok first i took everything apart, the headlight,the blinkers, the bottom plastic peice that goes under the heahlight with the allan bolt in the middle.than i took the plastic connection off the blinkers that connects to the blinker wire from the bike.now ones i had everything off i cut the plastic peice off useing a jigsaw..than u have to cut the rubber houseing that protects the wire because is to long and will hit the bolb if u dont.than i use a bench griner to smooth out the cut and make it nice and round.and than here comes the tricky part..i had to drill the rubber part that has a bolt inside which that is where the wire goes throw. because if u dont the wire will rub againts the bolb as well...i used a drill press for this because its so small and tight to do. than i had to figure out how to hold the rubber inside the light so i mabe a clip useing a cut washer with both sides with a angle so i could hold the rubber houseing inside tight...also i put some strong silicone to give it more strengt.than i had to cut the orange part of the light a little if not it wont go over it...but after all that you pretty much good...its not hard to do, i was just board and wanted to do a mod that dont require spending money so thats what i came up with..i did'nt like how the lights stuck out!!:a18:
great job i did mine last night and love the looks as well thank you for the info on the mod
Finished mine and love them
:a18: :agree:
looks good guys , i will be doiong that to mine shortly will post pics.
nice job..i wanna do this to my rear! can you post some close up side pics to see how it looks from that view?
when i get a chance, will do..
Very nice:bigthumbsup: i see u put a like a chrome striped around yours right where did meet!!
1 - 16 of 16 Posts
