I have those.Has anyone ever tried these? How would rate them?
http://www.directlineparts.com/product.asp?pid=6667&str=290
Thanks for the info :bigthumbsup: I have the Suzuki engine guard installed as well. Did you have to do any special fabrication (other than drinking the beer)to make them work?
Not really, had to add washers on the right bottom bracket to make it work, You have to mount the brackets on the inside of the engine guard and it works well.Thanks for the info :bigthumbsup: I have the Suzuki engine guard installed as well. Did you have to do any special fabrication (other than drinking the beer)to make them work?
Thanks! I think I'll buy the Revco.Not really, had to add washers on the right bottom bracket to make it work, You have to mount the brackets on the inside of the engine guard and it works well.
thanks . my girlfriend complains a lot about the heat on the normal pegs...specially when she is on eheel or sandals.any suggestions where to get them?They require the splined and Kuryakyn does not make them for the passenger set up. I am using the ISO Wings on mine or you can look at the Rivco passenger board. I am sure there are others.
Thank you very much. Got me the cobra ones....Will post some pics after they get here. Anxiously waiting for a ton of mods to arrive. jds, led ligths, backrest, front wheel, stebbel horn with ryans mod,passenger footrest, speedo plate,side bags.....and baldylatino is going to make me a plate holder...
They look GREAT in person. :bigthumbsup:
