1 - 2 of 2 Posts
Hey Lamont, I recently changed my blinker bulbs to LED bulbs. Will this flasher relay work? I saw in the manual that our flasher relay, is a flasher/kickstand relay : Thanks for any info you can give me. Blue Lionhttp://www.customdynamics.com/trick_flasher.htm#Standard_DOT_Flasher
I just got my service manual friday. It looks like we are screwed trying to use a "normal" electronic flasher. If it was jst a simple automotive type flasher then the electronic replacement at Auto Zone would fix this problem but the engineers at Suzuki have seen fit to combine the flasher relay in together with the sidestand relay. Honda had an oddball flasher on my 03' Sabre too.
1 - 2 of 2 Posts
