1 - 7 of 7 Posts
I posted my first video attempt at:
Can those that have done it before guide me here please. The video was shot in HD but after compressing for Youtube it lost 50% resolution.
I use Vegas 9 Pro for editing. To what must I render (avi, mpeg, Mpg4?) to get a decent video?
Tx & Regards
PM mooremj. He has the HD version and his look very clear. He should know. I know MPEG-4 is a pretty good high res. extension though, you could try that. Sometimes you have to play around with before you know which res. on from your editing software works best.
Honestly I think YouTube is gonna reduce the resolution to a degree no matter what you do as well. It always looks clearer on your computer than online.
take us on the Chapmans peak road to KLEINMOND............:bigthumbsup::bigthumbsup::bigthumbsup::bigthumbsup:
This is true, if everyone used HD, the bandwidth would go away quickly
not bad oom Wynand , so you see that HD does not help much or what ???
People, people.... are you using HD in vain or what?? HD can be two things: Harley Davidson or High Definition! ... just a bit of humor!!!
No HD (both) are great - it is fantastic! Give or take a few year and this will be the norm... you go figure! :joke:
Hi guys
You tube change its upload process about 6 months back things affected:
1) Full HD upload capped at 480p please note stand view is 380ish unless you select 480p (look to bottom of the you tube window LH side.)
2) I have found MPEG to be best compression rate and only compress to this format once full edit comes of your cutting desk software.
3) Music is the next thing being hit right now and the future will look even tuffer to get uploads with the sound tracks you have edited too...this sucks as you end up having to audio swap out with you tube library.
4 Finally between here and the States there is room to move on sound tracks taking out of iTunes (hence you can buy the track as an advert during you vid clip playing you may have noticed this??) however by record company say SONY that will be stripped and no audio will play in Europe....just ask Hardy!
Outside of that check out video channels from:
http://www.youtube.com/user/TVGeorgiaRoller
http://www.youtube.com/user/bmz2
http://www.youtube.com/user/M1800Rde
http://www.youtube.com/user/BIKEPAPARAZZI
and I do
http://www.youtube.com/user/BLVDRidersNZ
http://www.youtube.com/user/ColemansCruisers
Please link off the M109RidersVideo in the sig below.:doorag:
1 - 7 of 7 Posts
