1 - 6 of 6 Posts
Well, I have now had my first glitch with the bike.  The first week I noticed the speedometer jump back and forth around 65 to 75 mph.  It cleared up and haven't had any problem since, until now. I have 450 miles on it and just got back from a ride when the speedometer started to climb. It was way out of wack.  I was going about 30 and it showed 120. I pulled over and shut it off to see if it would reset.  After 30 seconds I started it again and it was still not working.  I went over and put gas in it and when I started out again it worked fine.  Sitting longer must of helped reset.  It must be an electronic odometer and probably has a bad sending unit.  Anyway, I hate to take it to the shop but I guess I have to. Other than that its a great bike and a blast to ride. This bike rocks!!!!
Ditch,
If you check my  message on the tech board under "speedo puked", you'll notice I had the same problem yesterday, and one guy who responded to me seems to have had it also.
That seems to be an indication that Suzuki may have a problem with one of their suppliers, and like you, I'd suspect the sending unit.  I'm wondering if you've taken yours in yet, and if so, what the dealer found.  I plan on contacting my dealer early this week, and any info going in would probably help.
Jerbear
I haven't had a problem since. Friend of mine said I may have got water in it when I was washing. I don't know if thats true but I did contact the dealer and he wanted it documented even if it doesn't happen again.
The funny thing is that mine responded just like yours. It wouldn't work right no matter how many times I turned the bike on and off. Then this morning, it resumed working correctly even though i went riding in the rain. I don't think moisture is the problem and a friend I ride with suggested it might be a heat build up problem either in the sending unit, the wiring, or somewhere else in the speedo system. Yesterday was the first time I put on over three hundred miles on the bike in one ride. I too will report the issue to my dealer and reccomend he contact Suzuki as we know of at least three people who've experience the malfunction, and I don't think it just disappears permanently by itself. I hope it does but I'm dubious..
Jerbear
make it 4, picked mine up friday and rode it 100 miles today and half way through my ride the speedo was jumping all over. On a better note i gave a R6 a run today it took him about 5 miles before he could pull away. but in all honesty he prob wasn't that expierienced. and when he finally got in front of me he kept looking back i think he was trying to figure out what kind of bike it was.
Folks: Your spedo is a electronic unit and gets its signal from the sending unit located on the transition unit at the head of your drive shaft. There is a excellent picture of the sending unit on the How to Board.
Sounds like a bad connection on the wiring. You can remove the screw on the spedo bezel and check the plug at the spedo. I would suggest you remove and replug the connector several times to ensure you have good contact. If you have some electrical contact cleaner give the connector a shot. I'd do the same at the sending unit. The slightest bit of corrosion in the wire connectors could cause the erratic spedo behavior you have described. Hope this helps!
1 - 6 of 6 Posts
