Fill plug for final drive is completed stripped out someone must have torqued it on there with a damn impact. The other hole to the left, not the axel screw, where does that hole lead to? Can I fill hub that way?
Welcome to the forum, Cheers.. 🍻Fill plug for final drive is completed stripped out someone must have torqued it on there with a damn impact. The other hole to the left, not the axel screw, where does that hole lead to? Can I fill hub that way?
Ok thanks it's just the bolt part to take it off. I just tried heating it up. That didn't even work.Is the plug stripped or the casing? I think the plug is aluminum and would think that would strip before the case would.
I would drill oversize, tap, and use an oversize plug for the rear. There is not a lot of material for a Helicoil, maybe 8 - 10 MM thick?Welcome to the forum, Cheers.. 🍻
The other hole is blind hole for use when that part is used on other Suzuki bikes,
so no go that way. IMHO the best way is use Helicoil or similar thread inserts system,..
Welcome to the forum!Ok thanks it's just the bolt part to take it off. I just tried heating it up. That didn't even work.
Same can be said for channel locks.Don't use a Crescent wrench next time , use a box wrench.
