1 - 6 of 6 Posts
Has anyone had this situation? Stopped off for gas yesterday and when I cranked her up to leave the FI Light came on. She runs fine and I did lift the tank and "wiggle" all the wires with the switch on, but it did not go out. I have never had this problem before. I did pull off the positive battery cable and left it off overnight hoping it would reset, but no luck. I have not made any changes or mods lately so I am at a loss as to what the problem may be:dontknow: I did do a search on FI LIGHT and found a couple of threads, but they were no help to me. Of course my local Suzuki dealer went belly up about a year ago so I can't take it there, not that I wanted to anyway. Any ideas on a fix? Any and all replys would be greatly appreciated!
Thanks guys
Look in Hink's frequently asked questions in the shop talk section and it will tell you how to get the code using "the tool". Post it up. I have a shop manual, I can look it up.
This has happened to me 3 times. First time, the light came on about 60 miles from home. It never went into limp mode and I got home fine. Next day there was no FI light. I assumed it might have been the pc3 and the throttle position sensor. I have switched to an fi2000r and have had no issues like that. However, I have noticed if you do not let the guages fully sweep and the fuel pump prime, it will come on. I then need to turn everything off and do it again. this happened twice.
That happened to me twice. Since then I do not start it up until the system check is complete. No FI light since.
1 - 6 of 6 Posts
