1 - 3 of 3 Posts
Sry for all the questions from a new to M109Rs...
Is there a link to the possible F1 codes that could be displayed.
I'm just trying to be prepared for that day.. probably jinxing myself haha..
FI light code key:
C00: None - No defective part
C12: Crankshaft position sensor (CKPS) - Pick-up coil signal, Generator
C13: Intake air pressure sensor #2 (IAPS #2) - For Front cylinder
C14: Throttle position sensor (TPS) - (Note *1)
C15: Engine coolant temp. sensor (ECTS)
C17: Intake air pressure sensor #1 (IAPS #1) - For Rear cylinder
C21: Intake air temp. sensor (IATS)
C23: Tip-over sensor (TOS)
C24: Ignition signal #1 (IG coil #1.1) - For Rear cylinder
C25: Ignition signal #2 (IG coil #2.1) - For Front cylinder
C26: Ignition signal #1 (IG coil #1.2) - For Rear cylinder
C27: Ignition signal #2 (IG coil #2.2) - For Front cylinder
C28: Secondary throttle valve actuator (STVA)
C29: Secondary throttle position sensor (STPS) - (Note *2)
C31: Gear position signal (GP switch)
C32: Injector signal #1 (FI #1) - For Rear Cylinder
C33: Injector signal #2 (FI #2) - For Front Cylinder
C40: Idle speed control valve (ISC valve)
C41: Fuel pump control system (FP control system) - Fuel Pump, Fuel Pump Relay
C42: Ignition switch signal (IG switch signal) - Anti-theft
C44: Heated oxygen sensor #2 (HO2S #2) - For E-02, 19, 24
C46: Exhaust control valve actuator (EXCVA)
C49: PAIR control solenoid valve #2 (PAIR valve #2) - Except for E-03, 28, 33
C60: Cooling fan control system - Cooling fan relay
C61: PAIR control solenoid valve #1 (PAIR #1)
C64: Heated oxygen sensor #1 (HO2S #1) - For E-02, 19
These are also listed in the "M109R Shop Talk" forum under the pinned post "Commonly Asked Questions"
BCS
1 - 3 of 3 Posts
