1 - 2 of 2 Posts
Greetings
Is there any extended bar ends for our bike? That will fit in place of the plastic bar end caps. I'd like to use the extended bar ends to mount bar end mirrors.
Semper Fi
GruntLeader
None that I know of. There's a metal slug inside the bars that need to be removed to install bar end mirrors. They are just tack welded in, if you remove the grips and look under the bars you can see where the welds are. Drill those out and you can pull the slugs out. They just add some extra weight to the bars to help dampen vibration.
1 - 2 of 2 Posts
