1 - 7 of 7 Posts
I do not know if I,m over reacting but since I've taken my battery out and reinstalled it the dash or spedo is making a buzzing noise,maybe its normal and was there before,just wondering if any other dashes make the same noise???? :dontknow:
Sorry the noise is there when I turn the ignition off thats when it makes the noise (that would of been nice if I put it in the original post) :dontknow:
Does it vibrate as the engine is shutting down? You said you took off the dash. I put a small rubber washer between the dash and the tank (where the hold down bolt goes through the dash) to isolate the plastic from contacting the tank. Might help if that is where your buzz is coming from. :dontknow:
Just the battery was removed from the bike when it would crank when hot.The bike does it if I ride it or just cycle the key off.. :dontknow:
1 - 7 of 7 Posts
