1 - 20 of 28 Posts
Na its No big Deal , at least the Suzuki One , dont know about the Cobra one
If I remember Right the radiator shroud Had to Be moved and Getting it back was a Learning experience :redfaced:,,,
but over all its not that Hard
Yup, if you've never removed the radiator surround that's probably the hardest part. But once you've done it, it's a piece of cake. The instructions that come with the Suzuki bars are pretty good.
Pay attention to the length of the upper bolt on the clutch side. If it comes through the frame too far and hits the water hose that's right behind it, you need to shorten it up a couple threads. Most are OK but some are a little long. Other than that, it's remove and replace bolts.
I didn't take my radiator shroud completely off, just took the top 4 screws out and pulled the top part of the shroud out far enough to get behind it to get the bolts into the guard mount and snapped it back together. I think it took me about 45 minutes to do both sides. Very easy mod.
I took off the radiator shroud, to have no crowding issues. It was no big deal, took less than an hour. Look great, nice and tight(factory bars). They do not disrupt the lines of the bike.
I put on the Suzuki guard and the only problem I had was that I had to bore out two of the mounting holes quite a bit to get the bolts through. I used a reamer to do the job and it worked well. Get them. It is a 2 hour job at the most. BTW, it has saved my bike 2x now (I hate to admit it....:redfaced:)
guards
Thanks everyone for your advice, yes I've had the shroud off a few times so NP there, thanks for the pics as well, I think it wont be a problem at all. And it's good to know they actually work NM!!
No problem at all. Mine was sent all the way from the States and with all the correct hardwares, it was done without any problem.;)
Mine took about 2-3 hours. I removed the cowlings completely.
Just remember to install the bolts & washers in the correct sequence. If I recall, the bottom connections to the frame had a 'stand-off' kind of configuration, and if you don't do it right, you'll be putting an unnecessary twist on the bars when you tighten them up.
All worth the effort though. I think they're the best looking engine guards out there.
the bolt on the left side of mine was a little long,just ground it down like zoom said. other than that very easy job. just sucks now i have to loosen the right one to get the plugs out of the front cylinder.
I like the looks of these because they don't stick out TOO far. But do stick out far enough to protect the gas tank too?
Thanks,
John
1 - 20 of 28 Posts
