Hi All
I am having some trouble with the O2 sensor wiring on my european spec M109, and was suggested to try asking here since Australian bikes are equiped with O2 sensors as well.
Anyway, m bike has been equipped with an aftermarket exhaust without O2 sensors, but I am reinstalling the stock exhaust and have plugged in the sensors, however I am getting an "FI" error indication in the main display.
I have noticed that two wires are removed from the topmost connector on the ECU (not the pin 7 to disable the SET actuator, my wires are on the other connector), and I suspect that this is done to disable the O2 sensors, and may cause the error code now that I have plugged the sensors back in.
I would like to reconnect the wires but problem is I dont know which one goes where. The wires are both white, one have a thin blue line and one has a thin green line. The two empty holes in the connector are number 3 and 6 from the top.
I would be very grateful If anyone could check the wiring on their ECU and maybe be able to direct me on how to connect the wires.
Thanks in advance
Thanks in advance
