1 - 6 of 6 Posts
i am looking to buy ducks air cover. just want to know if with the increased air flow will i see any increase in performance.
thanks guys.
If you use a K&N air filter the increased air flow will show an increase over the stock setup. Even if you use the stock filters there might be a bit of an increase.
keep in mind that in order to see an increase of performance, there needs to be a substantial increase in the amount of air flowing through the air covers. make sure that you use K&N air filters and also be sure to have ducks cut a design that really opens up the covers.
:agree: You need to have at least as much area as the opening in the back gives you now if you plan on closing the back opening off. Otherwise you restrict the flow. So plan something that is nice but has some open area to it, then add the K&N filters.
1 - 6 of 6 Posts
