1 - 5 of 5 Posts
I THINK this is the exact same liner that comes with the Phoenix 4.0 jacket(since its also the one you get with the 3.0), if so I have used it in the rain and it works quite well... Its waterproof up to at least 80mph, I wasn't going to go any faster than that on new tires that still needed to be broken in a bit. It wasn't particularly cool the day I had to use it, but I can deffinetly say that it stops wind and will heat you up quite a bit. Also, the liner for the phoenix liner has a velcro-ziper-velcro overlaping front seal that seems to be extremely overdone... but then I didn't get wet where the liner covered so I guess it does what its supposed to.
Dalton
Ditto I have the Phoenix jacket and it makes a difference w/the chicago weather it is most definitely worth it.. :bigthumbsup:
How is the size?
Should I buy the same size as the jacket I wear? or a size smaller so it is easy to wear under the jacket??
My jacket has an unsulated "VEST" already, so it would be under that too.
I wear a 5xl, but could wear a 4xl in the jacket but it would be a little tighter
Sledzep
1 - 5 of 5 Posts
