1 - 11 of 11 Posts
thanks for the link,however i still need to no,does the
DLP Steel Swingarm and 300mm Metzeler plug&play!
i ask this because ive read the avon does but does the metz&dlp swinging arm(not fabricated)
plug&play
thanks!
LEDs
See thread link below. I just ordered one from them today and will be here next week, I think most people are waiting 4-8 weeks to get them.
Others will chime in soon or point you to other threads about the subject!
http://www.m109riders.com/forums/showthread.php?t=134941
Very very nice.... by the way where did you get those grips with the LEDs integrated into them ??? sweet !!!!!!!:2cool:
crossq...
Discussion Starter · #6 · (Edited)
topher u say u ordered and ure getting next week then u say people
are waiting,how does that work!
also ure getting the swinging arm how about u doing us both a favour&search
because too me i cant find the awnser does the dlp swing arm plu&play with
a metzeler 300&dlp 10" replicator!
thanks!
I run the Metz 300 on the steel swingarm. It's very tight with the 300 metz and from what i have physically seen on other bikes, it really depends on what rim mfg you use. Example, i run RC component 10" wheel and the metz is tight but works. Another bike i saw was running a Costal Moto 10" rim and the metz hit the swingarm severly and needed to be shimmed alot. From what i gather different wheel mfg use different hub spacing. Hope this helps.
:agree: The Avon should offer more clearance than the Metz. If I had to do another, the Avon would be the way to go. You will need to do some clearancing with the Coastal/Metz combo.
thanks!
Read L.T.T.'s post above yours, it will answer the Q. It is not the swingarm/tire combo, but rather the rim manuf/tire combo that is the real issue.
thanks!
I believe I got real lucky and they happened to have one. I asked if I could get a Chrome one and he said 4-8 weeks.
I think they just don't make alot of them at a time?
crossq...
The grips are from xoprodox (you have to email them if you want to buy some until the web page is back up). My handlebars were drilled where the holes are in the grips and leds put inside the handlebars.
http://www.xoprodox.com/
1 - 11 of 11 Posts
