1 - 6 of 6 Posts
I finally got around to de-beavering my '07 LE. Right now I am installing a custom license plate bracket to the two stock bolts everyone uses to mount the bracket. I marked and drilled the bracket to match the two holes centering the holes on the bracket. When I installed the bracket it was not aligned center of my rear tire. It needed to go to the right about 3/8". I decided to cut a slot (instead of holes)to be able to adjust the lateral position.
Now, I can align the plate with the tire but, guess what? It's not aligned with the fender.:edit:
I never noticed before that the fender was not aligned exactly with the tire. Something is going to have to give! If I can't get everything to line up I'll have to go seek counceling.
Anyone know any good counselors?
Seriously...anyone have any alignment issues like this?
Same here. I just centered it to the bike. It's maybe a 1/4 off center on the tire.
Mine is offset for sure, I noticed it when taking the tiny screws off under the fender, the right side had to use a stubby screwdriver, the left straight shot up with longer one. dont know why this is. im running a 250
1 - 6 of 6 Posts
