1 - 10 of 10 Posts
I’ve had this issue every time I try to get the washer off, either the engine oil drain bolt or gear oil drain bolt. I always ended up cutting it. Does anybody have a better solution?
Hand Finger Gesture Body jewelry Thumb
Do it all the time the following way and it works like a charm. I pry up enough with a small screwdriver that I can get plyers around it to grab. Doesn't take much. Then I have a screw gun, but you can use a drill. Get the adapter that you can put a 17mm socket on and spin the bolt counter clockwise while squeezing hard on the plyers. Do it over a rag so when you drop the bolt it doesn't go running all over the place.
I have never had a problem getting the crush washer off from under the head of the drain bolt. Perhaps I don't tighten the bolt as much as others. In fact, I've had the washer come off the bolt when I drop the bolt and washer in the drain pan.
It depends on the washer. If you are using a genuine suzuki washer, it will flatten and do that . If you are using an acceptable one, that looks more like a regular washer that is flat all across, they drop right off. The suzuki version has a lip that when crushed, flattens out and will get right up into the thread.
I've never had the problem either. But, I rolled on the original crush washers the bike came with from 2006 to 2018. Never leaked, never had a problem. In 2018, I changed them both for the first time. Mainly because when I bought the oil and filter, the guy behind the counter included them without me asking for them. So what the heck, I went ahead and used them . Didn't have any problem getting the washers off the plugs after 12 years of not paying any attention to them.
Correct! The ones that come with the Zuki oil-change kits are a PITA to get off. I ruined a drain plug trying to get one off. I have a bag of flat crush washers now.
I have had similar issues before. I use a pick to get the crush washer off of the plug head to get a gap big enough to use my dikes and cut the washer. I then use the dikes on one side and grab and roll the dikes and it will bend the washer until it gets off the plug. Very similar to how I remove cotter pins.
Not sure what I've been using for crush washers but I've had about 20 motorcycles over the past 59 years, and I don't think I've ever bought a crush water. And I don't recall any leaks from the drain plugs. In fact I discovered a crush washer in the drain pan after filled the crankcase with oil. I watched for an oil leak and didn't see one.
1 - 10 of 10 Posts
