got a craftsman lift today for $150. here's some pics...
the fit on this thing is very close. there's only about 1" on either side of the lift sticking out from the frame. the center of gravity is also in a funky spot on the 109. the frame itself starts curving up before you can get the lift under the right spot. this forces you to keep the lift a bit too far forward, otherwise it will be on the less sturdy protective plate underneath. it works, though. just gotta be careful.
the lift is very easy to assemble (just stick the rod into the main assembly and you are done). it's also very easy to operate. it has 4 locking positions, and to let it down you just twist the handle.
some of the other lift solutions might be better for this particular bike.
