I noticed I have a slight tick sound when cruising, also I might be crazy but it seems like the front brake is sticking. When I pull the front brake in should I see the pads move? Also I decided to check the oil level since I just changed it last week. I cruised around for awhile then came in the garage, shut it down and let it cool down for 3 minutes while I sat on it and kept it level. I checked the oil after 3 minutes and its not showing up on the dipstick. I leaned it over on the stand and then let it sit for a couple more minutes and its in the middle. Is this correct or should it be showing it up when the bike is level?
