1 - 4 of 4 Posts
Went to go for a ride earlier today and the bike would not start. By the lights on the tac housing it showed that the coolent was low. Checked coolent it was low, so I filled with Suzuki brand coolent mixture and put the bike back together. Problem, the light still comes on and the bike will not start. Nothing from the ignition and acts as if the battery is dead but I have horn and lights. Any recomendations as to what to look for will be appreciated.
Reed
Discussion Starter · #2 ·
The kill switch is not on, the kick stand was up and clutch in. I am going to check clutch adjustment as soon as I get the opportunity.
Reed
If the coolant was low and there are no visible leaks, the coolant may have leaked into the cylinder. Liquid will not compress so the engine locks up. Remove a spark plug from each cylinder and see if it will turn over and if coolant comes out.
1 - 4 of 4 Posts
