1 - 4 of 4 Posts
When installing the Cobra Dragster pipes, you have to keep the now unused exhaust control valve actuator.
Can it be removed completely?
If no, why not?
Thanks.
Rick.
If you want to keep the SET valve installed, there is a cam that should come with the pipes that you will install on the valve.
Or you can bypass and remove the valve completely. Somehere will chime in with a link to disable the SET.
1 - 4 of 4 Posts
