1 - 7 of 7 Posts
Will not go into 2nd nor 3rd nor 4th. When in 1st and the clutch pulled in the bike still pulls forward and its hard to or will not go into 2,3,4. could any one help with this problem, i really want to ride tonight.
2 fixes.
Easiest one is to remove the rubber boot from the end of your clutch lever. Turn the cable out meaning the thumb screw gets further away from the lever. Adjust it out and then while in first rev the engine and if it lurches forward adjust it out more. Once it doesn't lurch on you it should shift.
Tighten the ring against the lever and it will now hold your cable in place.
Did the quick fix and it's working perfect........ Thanks very much.........................
1 - 7 of 7 Posts
