Hmm, then your first post is very confusing indeed or I am reading it wrong.This will be 1st clutch replacement, been through 2 clutch cables, almost have 40k miles, plates had to pryed apart, look burnt, I can post a pic later...
Not sure how to interperate that statement except that the clutch has been changed once before, because it sounds like you are saying it came with a 6 stack (Hyper) clutch when you bought it.Replacing clutch plates 2008 M109R, should I go with hyper clutch or stock? It came with the hyper set but is it worth the 500 bucks to replace with same?
The 2008 did not come from factory with a 6 stack (Hyper) clutch. It has a 5 stack clutch, so if you have the 6 stack (Hyper) clutch in it now, then the clutch has been changed before.
Anyway, now we know......I think.
BCS
LGB/FJB
