1 - 9 of 9 Posts
Every big bump in the road makes my clutch lever rattle around like crazy. It'd be nice if there was a bearing upgrade kit to keep it from rattling up and down and only allow it move in and out..... the way it was designed ::)
I HAVE NOTICED THIS ALSO. ONLY RATTLE I CAN HEAR IT WOULD BE NICE TO CORRECT THIS PROBLEM. HAS ANYONE NOTICED THAT WHILE CRUISING IN GEAR AND FINGERS ON LEAVER QUICK ON AND OFF THE THROTTLE I CAN FEEL THE CLUTCH LEAVER MOVE IN AND OUT SLIGHTLY. IS THIS NORMAL?
I think if you adjust the lever out away from the bar that it will press against the rubber boot/cover and won't rattle. Mine does not and it's adjusted out far. I think the freeplay is not up and down but back and forth.
JMO Check it out it might be the problem.
I had the same problem and adjusted the slack out of the lever so it would not be so loose. I did not adjust it to the point that the lever was forced up to its stop just near it. NO MORE SOUND! :bigthumbsup: :doorag:
1 - 9 of 9 Posts
