1 - 3 of 3 Posts
Does any one have a service manual that could help me adjust the bottom adjustment for the clutch. The nuts came loose a week ago and I moved them and I don't know if it's right or not I would appreciate any help with this matter.
This is a exact quote from the Service Manual, page 2-22..... Remove the secondary gear case cover.....Loosen the lock nut (top) and turn the cable adjuster to obtain 10-15 mm (0.4-0.6 in) of free play at the clutch lever end. Tighten the lock nut.
Thanks bob109, I will give it a try
1 - 3 of 3 Posts
