1 - 3 of 3 Posts
whats the best way to adjust the clutch perfectly? how much play should be in the handle if any? i searched, but noyhing satisfactory.
john
the mechanic at the suzi dealership told me it's supposed to have 2-3 mm play at the handle. fold back the rubber covering it, and you'll see the gap between the lever arm and the mount. since it's still clunky there, i removed the 2-3 mm play. don't over-do it though, because you can leave your clutch partially disengaged and burn it out. i've only adjusted it at the lever, not near the tranny.
1 - 3 of 3 Posts
