1 - 8 of 8 Posts
Checking oil level
Well....... After all this time, does anybody have an adequate, quick and simple method of checking the oil level????
Would like some help please.
Woody from Va.
Re: Checking oil level
yes, do it strictly by your manual. this is best and most accurate way.
ppridgen1 said:
yep and I've found that shutting her down when I get home from a ride and then letting her sit for three minutes,followed by the oil check proceedure gives me an accurate reading and piece of mind ! :bigthumbsup: :doorag:
This is the easiest way to keep up on it! :bigthumbsup:
Yeah, I do. Run the bike 15 minutes, let it cool 3 minutes and check it with bike lifted off the stand. :bigthumbsup: All the people that keep asking for a shortcut need to just accept the fact that checking the oil on this bike is a process that has to be followed. It's the only way you are going to get accurate measurements.
this IS the only way that works. trust me i have been thru the over fill BS & do not want to go thru that again
1 - 8 of 8 Posts
