1 - 3 of 3 Posts
I changed the engine oil and final drive oil today. When I took the filler cap off the rearend, the oil was not level with the bottom of the hole, even whe sitting on the stand!. It appears my final drive oil level was low. :verymad:
Guys who just received your bikes or have not changed fluids yet, you may want to check this! :bigthumbsup:
My diff oil level was the same as yours. Not low enough to damage anything, but lower than the manual recommends. This gear oil should be changed at the first oil change anyway. You will probably find small metal shavings on the magnetic oil plug. Be sure to clean it well.
1 - 3 of 3 Posts
