1 - 3 of 3 Posts
Hello,
I just moved from from the US to the UK and must alter the alignment of my headlight beam so that it points to the left (UK) instead of to the right (US). Can anyone offer advice on what can be done to change how the beam is is aimed?
Regards,
GW
Turn your bars all the way to the right. Look for a hole in the black plastic housing behind the headlight. It will have an allen bolt in it that you turn to adjust the headlight left and right.
If you turn the bars to the left, you can see a hole on the other side that lets you adjust it up and down.
What you are looking for is a round hole about the size of a quarter. The bolt is just inside the hole. The bolt is a black color so a flashlight may help find it.
1 - 3 of 3 Posts
