1 - 4 of 4 Posts
I decided to tackle the tach relocation mod tonight and when I was taking the bars off I found that 3 out of the 4 hex bolts were loose! :eek: I urge all of you to please check your riser and handlebar mounting bolts to make sure they are tight. I'm going to Loctite mine in the morning....time to do another top to bottom, front to back inspection of the bike...
Someone else talked about this in another post. They found the same loose bolts.
Like Lamont said, A V-Twin has a way of loosening the damdest things.
Thanks...I get lax with checking those bolts out...guess I better!
Devilish
1 - 4 of 4 Posts
