1 - 12 of 12 Posts
Yesterday I tackled the task of installing my Stebel horn & engine guards.
Everything went well till I went to reassemble everything. As I was reinstalling the top screws on the radiator one broke. looks like it was partially broken from factory and I just finished it off. :edit:
Now what is the best way to get the broken part out ???
There is nothing sticking out the front to grab with a vise grip but their are a few threads sticking out the back side. Kinda hard to get back there.:-\
I dont have a fix but I am posting to keep the thread up top :) I am so sorry that happened, I hope its easy to get out.
you might try gripping it from the back and try it that way.
or you might have to drill and tap. sorry those are your options......:-\
It depends on how tight the threads are. If you can use a left handed drill bit, and its not too tight it will come right out. Or you could use an easy out, etc
:agree: I'm not sure how much room you have, but you could try locking some small vice grips on the back and thread it through if the easy out doesn't work.
One trick to try is take a Drimel with a cutting wheel attachment and CAREFULY cut a X in the exposed portion ,and use a Phillips screwdriver
Probbly it would be safer to remove it from the back ???
not much room back there.:'(
i have done that before as well. but i think that this is a very tight spot...:dontknow:
I just bolted everything back together. ill let that project for the winter. :dontknow:
pynikal is right , That will place all the Vibration on the Remaining attachment point ,could be expensive if you put it off too long,
decide carefuly
1 - 12 of 12 Posts
