1 - 5 of 5 Posts
Will the brakeaway cruise for sale on direct line fit over the KUR-6235 Kurkylan hand grips. Brake away says they fit over the grips but ours are larger than most. Am i right?
I will be installing my Brakeaway today. I don't have the Kury grips but they did go over the Kurys on my VTX. Soap is required though.
The Breakaway control comes with three (3) thicknesses of rubber gasket that goes over the grip. I used the 'medium' size for the standard M109 grips. The 'thin' gasket is for larger diameter grips, like the Kury's. Should work perfectly.
INSTALLED THE BREAKAWAY OVER THE 6235 GRIPS ON 109. INSTALLED THE THINNEST RUBBER INSERT AFTER SLIDDING UNIT ON MOST OF THE WAY. KEEP IT LUBED WITH DISH SHOP AND IT WILL GO ON.
1 - 5 of 5 Posts
