1 - 9 of 9 Posts
2009 / VZR1800
Can anyone help me identify this brake pedal? I want to buy a replacement peg if possible.
David
I unfortunately can´t, but I remember way ago someone cut
off the OEM welded peg and attached aftermarket rubberized
matching pegs on both, shifter and rear brake. So I would google
aftermarket pegs matching yours... Sorry I am no better help..
Cheers!... 🍻
I did both my brake and shifter like that. One is the 4 ring and the other is the 3 ring Longhorn. You can either get those or find something similar on ebay. You'll need to figure out what thread it has on it, I think mine that I drilled and threaded into the brake was a 5/16 x 18 thread, but it's been a while so I'm not sure.
For the shifter I found one that had a tapped hole in it instead of a stud, and attached it with a bolt.
1 - 9 of 9 Posts
