1 - 17 of 17 Posts
$ 88.00 marked down from $ 159.00 :bigthumbsup:
I think I saw that jack advertised. Did it look like this one ? :joke:
And I bought 2.
1 for the 9 and 1 for the cousin (my wife's C50T).
P.S. How do I get it to lean like that afore I stick the beams in?
Bought one a little while back, but the pads are not wide enough for the frame rails under the engine. Its only wide enough towards the back where the skid plate it.
That's worthless then,,,,,,,,
Adding some channels is a good idea to extend the rails, but what I do is use the jack as is at the rear of the frame and jack it up high enough until I can slide a pair of jackstands under the front frame then lower it on. The bike is very stable with the stands up front and the jack on the back. I have it stored this way right now.
Does crappy tire sell more than one model Jack or just the one that don't fit?
Anyone know where to find one that is compatible with the nine here in the GTA :dontknow:
NAPA sells a better jack,wider heavier and yup you guessed it more $. I have one and like it. :bigthumbsup: Side buy side with a buddies it's worth it.
I have the red CT jack. Its close, but works fine, with about an inch of width to spare. Just have to put it in the right spot. I always check to make sure i;ve got both rails on before i jack it up. Sounds a little difficult, but really isn't.
Go with the Princess Auto one, works great for my nine and cheaper than Crappy Tire. Better quality too....heavier gauge steel.
I seen that one the other day....they couldn't tell me witch bikes it worked with,but it did look beefier than the crappy tire model...thanks for the heads up SS,think i'll pick it up next time through there..:bigthumbsup:
1 - 17 of 17 Posts
