BLK N BLU9
Thanks it is very involved, if you need any info on some of the challenges PM me I will give you as much info as I can.
BLKNBLU
Thanks for the compliments, Iam very happy with the results. There was no real problems with powder coating the forks just had to break everything down you cant have any rubber obviously during install we just put a small wood wedge in the triple trees and greased the forks up and they slide right in. The upper triple tree was a PITA the rubber bushings that the riser bolts go thru had to be removed and they did not come out in 1 piece so I fabricated some steel ones and so far so good. The stock mirrors that I thought were steel are actually plastic so they fell apart, it was actually kinda funny but rather expensive to replace I went with some joker mirrors they will be here in a few days.
