I contacted Barnet Clutches last October looking for longer brakelines for my C. at the time they did not offer a set to fit.
I just received an email from Barnet, they are now making their "GoodRidge" brand Stainless Steel brake lines for the "C". Although they are not listed on their website yet, but the part number is:
Brake lines: 211-70-12016
To order a different hose type, simply change the first three digits accordingly: 212= Carbo 213= Black 216= Platinum Series For brake lines over stock length, simply add the number of inches to the end of the part number. (ie. for a +3 brake line the part # is 211-70-12016-03).
Also Cables are available
Clutch Cable: 102-70-10009
and also Throttle
Push: 102-70-40009
Pull: 102-70-30009
To order a different casing type, simply change the first three digits of the part number accordingly- Stainless braid w/clear coat= 102, Carbon Coat= 104, Platinum Series= 106. For cables over stock length, simply add the number of inches to the end of the part number.
I've been running with 6"straight risers on my bike since I bought it, and all my lines have almost no play. Now I'll finally be able to switch to 6" pullback risers and get lines and cables that fit correctly.
I'm not sure if HDL is a distributor but I'm sure someone will know.
and also Throttle
Push: 102-70-40009
Pull: 102-70-30009
