1 - 4 of 4 Posts
Anyone ever do or know if you can put a plate under the Raw Design undertail turn signals? I'm not a fan of the side mounted plates.These ones http://www.directlineparts.com/product.asp?pid=6808&str=290
I don't know what the part looks like so I can't tell if there is room to make a plate bracket. Maybe someone has a pic of the underside of it installed or off the bike?
Thanks,
Nate
There is plenty of room to put the plate under that.
It is just a thin strip.
You will have plenty of room on the bottom of the fender to work with.
SR is correct. I have the exact setup your talking about. Plus you can always add a nut spacer if you need alittle more clearance for the plate.
My "bracket" to hold the plate is a flat piece of steel.
I mounted it to the under side of the fender where it starts to slope up inside.
It comes nowhere near the edge.
1 - 4 of 4 Posts
