1 - 11 of 11 Posts
ok as some of you know my bike has been sitting on a jack all season so far but i should be back on the road on thursday my question is when i change my oil should i just drain it because all the oil is at the bottom of the motor due to sitting all year or should i warm it up first then drain it:dontknow: THANKS
It shouldnt make a difference. Level the bike, remove both drain plugs carefully. Let it sit. replace oil and filter. Run 15 minutes and let it cool. Check and adjust. Pretty straight forward. Im not sure why you would want to run then drain. Want to explain?
OK here is the "Big Papa" Oil change way
he isn't here anymore , but everybody here
still kept a few precious info from him .
Run the bike until it is completely warm.
Leave it on the side stand, TAKE OUT the dipstick
and undo both drain plugs. Once it stops draining,
stand it up and shake it side to side and then leave
it upright for like 5 minutes to get the rest of
the oil. Put the drain plugs back in and undo the
oil filter. Fill the new oil filter all the way up
with oil, one time, and let it absorb the oil.
Rub some oil on the filter o-ring and put it back
on until you feel it start to snug up.
Then turn it 2 full times. Wipe everything down.
Add 3.6 quarts,( 3,41 litres) fire the bike up for 5 minutes to
make sure there are no drips. Don't even bother
checking your dipstick.
1 US gallon = 4.0 US quarts = 3.785 411 784 litres
3.6 Quarts = 3,4068706056 litres
( metric measures for canadian members)
warm it up.
I would say warm it up also. If its been sitting that long I would want to warm it up. Maybe even throw some fresh gas in to mix with the old.
Oil !
While we are on the subject of oil changes,have/are any of you blokes over there used/using the Castrol Power RS V-Twin 4T oil in your bikes.Aparantly it has been available to you fella's for the last 6 months,according to Castrol.Anyone out there using or has used this oil,feedback would be appreciated.Many thanks in advance.KEZZ.:bigthumbsup::bigthumbsup:
just drain it out , it is all down the bottom why pump it back up there just to wait longer for it to come out?
you know you want to................. DRAIN IT NOW!:bigthumbsup:
1 - 11 of 11 Posts
